Monroe County Fire Bleed Thru
Does anyone else hear what sounds like bleed thru on monroe fire talkgroup...?? sounds like another county or something...also thought i heard addison twp in oakland county coming over ??
KB8UYC
Ypsilanti Michigan
What you are hearing is 154.430 simulcasted onto the MPSCS talkgroup. Get use to it. It is going to be like that for a while. They are working on trying to get a pl tone for it. You will hear other departments if they have it patched, which they should have it patched all the time!
Hope that helps
Eric
RESCUEME1390
Michigan
Monroe county bleed thru
Lenewee county use to use that 154.430 freq for along time. Monroe county got tired of the bleed thru and stired up a big stink about it. Lenewee County then changed there freq but still uses that as a fire ground channal. It is very possiable that you heard Addison on it.
rdale
Lansing, MI
Not any more as the patch was turned off.
