County changing to new fire paging system to improve coverage
County changing to new fire paging system to improve coverage and alerts.
www.monroenews.com
Time to figure out the talkgroups.
I was not a fan of the move to MPSCS PageGroup paging. Stay with analog VHF, it is much more reliable.
1) The mixed delays of audio, during the page, made the dispatch audio a jumbled mess. (Turning off the alert buffering on the G4 led to widely varied alert durations, often with no audio alerting.)
2) The pages are limited on which towers they are carried, so fringe coverage is nowhere near as reliable.
The only real benefits were being able to use the pager to monitor radio traffic without using up battery on the portables, and being able to scan more reliably than most scanners were able to, especially in LSM covered areas.
1) This is a problem. Once solution is to use a console tone prior to the voice announcement. A sound is required by nfpa anyway prior to announcing a call over a dispatch channel.
2) Depends. If you have a single conventional site, MPSCS paging should have much greater geographical coverage as they usually set the pageroups to several surrounding 'critical' sites. In-building coverage can be greatly reduced in comparison to legacy paging if not using simulcast system. Scan is also another issue- where traditionally paging and dispatch traffic usually occurred on the same channel, one could usually hear all the activity if in range. Thanks to 'critical sites' you may get the page fine but be listening to a neighboring site without the other talkgroups affiliated to it.
The problem I refer to is the non-delayed audio from the base station and portables,, mixed with audio delayed by the alert tone duration. In our case, I had the alert tone for three seconds, to replicate the B tone length, when we used Minitors on VHF. That results is a mishmash of audio, that was very difficult to pull anything useful from.
MPSCS minimizes the towers the pagegroups are carried on, so as to not have pages delayed by a busy site not having an available repeater. Obviously, they adjust the mandated sites, base on required coverage.
Yes. There are special talkgroups for paging, called pagegroups. They are treated a little differently than regular TG, as they will not normally have a site affiliation, and are mapped onto the desired sites by the NOC.So the P25 paging is over MPSCS at 700 and 800 MHz? I so don't agree with doing that. Like you said, just stay at VHF.
