I am having trouble programming the Montclair Twp (Essex Co) P25 system for some reason I can not get it to work on the BC 996D. I have the system working the the BC 796D and BC396T any clues. Thanks
Tony
Tony
Also, it's a Motorola 3600 Type-II system, not a P25.
Make sure you set the system up correctly from the beginning... :wink:
It's listed here in the DB as analog and P25.
I have 2 996's programmed using UASD software the same way RocketNJ does. I am in Verona and have no problems picking up Montclair. Perhaps you have another problem with the radio. Do all your other systems work properly?
