Monterey County "Operation Impact"
jm_460
Monterey County, CA
As some of you have heard, local law enforcement agencies have recently teamed up to create the joint operation "Operation Impact" to turn up the heat on Salinas gangs. I'm hearing "Operation Impact" traffic on Salinas PD channel 2 and on S.O primary, but all the action is on Salinas PD channel 2. LOTS of traffic and lots of 10-3's. I keep hearing a "channel 4". I can't seem to pick anything up on my band searches, though.
Mick
Western U.S.
Here are some of their channels I've logged, maybe one of them is channel 4? The old Gov't Radio Systems from 2000 by Bob Kelty listed Channel 4 as 460.375 146.2 simplex.
460.175R 146.2 Dispatch
460.025R Secondary (146.2 mutual aid)
460.300R 131.8
460.350R 146.2 Records
460.375S Tac 146.2
460.500R 146.2 Secondary
cousinkix1953
Salinas PD channels:
1. - 460.175 R dispatch (152.135 VHF simulcast)
2. - 460.500 R tactical
3. - 460.350 R records
4. - 460.375 R detectives P25
5. - 460.300 tactical
6. - 460.025 CLEMARS GOLD
Sheriff
1. - 159.090 R dispatch
2. - 158.910 R records
3. - 153.815 R tactical *
4. - 159.210 jail
5. - 158.745 R coroner ?
6. - 155.910 mobiles
7. - 155.970 SWAT
8. - 154.920 CLEMARS WHITE
9. - 155.475 NALEMARS **
*This is a new tactical frequency that used to be the agriculture dept. repeater.
** Watsonville PD's gang task force uses this frequency; so don't be surprised if the MCSO also pops up on this national mutual aid channel too...
jm_460
Monterey County, CA
That 158.745 is actually used by county animal control. I know that animal control does not operate 24/7 and they're on-call after closing hours. Maybe the coroner operates on this frequency after hours?
Soledad, CA
Channel 4 is UHF 460.025 CLEMARS simplex if you dont live in Salinas good luck hearing it.
channel 4 is channel 8 and channel 6 is 4
yes it's use for county animal control and also used as two-tone page out Child Protective Services "CPS". It use to be use by the health department but they are on 800mhz now. And no the coroner operates on SO primary their call signs are King units like "king5"
And for 153.8150 pl 162.2 is used for a tac, but only after hours by MOCO law enforcement. The techs have it patch to SPD channel 2 for Operation Impact for SO and CHP that use VHF.
Also check out the Monterey county data base I added some new stuff and fix some stuff.
