Montreal Fire channels with my BCD 536HP
zapper1948
Montreal, Quebec
Craziest thing. I put my new Hg vertical base scanner antenna on a horizontal level and now I am getting the Montreal Fire channels, but only in the morning and many times the voice sounds like it is underwater.
BC_Scan
Vancouver BC
Suggesting you need to re-orient the antenna , WTH is Hg ? Can you point to a picture or URL. Google is not feeling the love ???
Do you mean simplex or the trunk system ?
mciupa
Moderator
zapper1948
Montreal, Quebec
I added an inexpensive pre amp between my coax and unit and now the fire channels are flowing like water. Go figure!
BTW, I am using the small inexpensive pre-amp without any power supply.
jonwienke
More Info Coming Soon!
VA
If it has no power supply then it is not an amplifier. It might be some type of filter, but an amplifier has to have a power supply.
jonwienke
VA
The power supply may be a battery instead of a wall wart. But an amplifier has to have some energy source to amplify the input signal.
