Craziest thing. I put my new Hg vertical base scanner antenna on a horizontal level and now I am getting the Montreal Fire channels, but only in the morning and many times the voice sounds like it is underwater.
Suggesting you need to re-orient the antenna , WTH is Hg ? Can you point to a picture or URL. Google is not feeling the love ???
Do you mean simplex or the trunk system ?
Antenna is made for outdoor use as a base scanner antenna. ((((( The HG Base Scanner Antenna outperforms a la rge selection of scanner antennas in the market ))))). The HG – Base Scanner Antenn a. The antenna also covers the Aircraft Band 108 to 137 MHz & the CB band!
I added an inexpensive pre amp between my coax and unit and now the fire channels are flowing like water. Go figure!
BTW, I am using the small inexpensive pre-amp without any power supply.
