W9DPY
Happy Thanksgiving! I have an Icom IC-R7000 that has the "receive drop out" issue. This was discussed in-depth in this forum under the title "Unusual ICOM R7000 problem". Here's my issue - I know I have the DC-to-DC capacitor issue. I'm about to order a cap kit from a guy on Flea-Bay to replace those. However, many of the posters said that the real issue is the heat generated by the internal AC power supply. And that using an external DC power supply is a work-around for this issue.
Here's what happened. My DC plug is on the back of the unit, next to the AC plug and fuse. Some are like this and some units don't have the external DC plug. In an effort to see if an external DC supply would work, I cut the jumper wire on the external plug (used for AC operation as a trigger) and soldered on some leads for external DC power. I turned on the unit, got the meter to work - but not the display. I tried a different supply (Astron 35M) but the same thing happened. I re-soldered the jumper, plugged it back in and checked it on AC. Everything good (meter and display), but I'm sure the RF sensitivity drop issue is still there.
Anyone run into this? Also, anyone know where you can get a pre-made 12 VDC power cable for this unit? FYI, for those who didn't read the original post; my unit has RF for about 5 minutes and then starts dropping. You have to shut the power off then on to get it to work again. As the unit warms up, the interval between shut-downs grows shorter. That indicates a thermal issue.
Feedback appreciated!
Dave - W9DPY
Dave - W9DPY
