Morris County Setup
SHU21
NJ
I am able to setup Conventional Systems in Morris County, also West Orange EDAC system. But I cant setup the Morris County Site. Any suggestions what I could be doing wrong, I use freescan can anyone send me a file that they have the Morris County already setup on freescan?
THANSK!
DannB
NJ
Morris County
THANSK!
morris county trunk system M.I.R.S? did you remember to apply the upper base freq. in the set up . what exactly isnt working I will try to help ya out my scanner is programmed with Morris county so i am familiar with the system..
SHU21
NJ
Yes I am trying to setup that sure. Where do put the upper freq in free scan
DannB
NJ
Morris County
Well That I dont Know I have the Butel Software, I dont use the freescan software. If That is all you have left is program the upper base freq. you could program it manually,(directly in the scanner) I dont know what scanner you have ,I have Uniden scanners, and programming some things manually in a pinch isnt the end of the world.(I know the software makes it much easier)If you need the upper base freq. let me know ill give them to ya..
