works fine. Did you set it up as Type II and use the custom table listed in the RR database? The channels should be set for NFM mode.
Where are you located? They have 4 sub-systems to cover the county. Program the sub-system to cover your area.
Don't forget it requires two table entries.
First is
Base 471.000
Spacing 12.5 kHz
Offset 380
Second is Base 476.000
Spacing 12.5 kHz
Offset 520
If you use the ARC396 software, you can PM me to arrange to send me a copy of your programming file and I'll check it for you.
George
