MOSWIN :: New Americus 700 site, or maybe Kingdom City 700 changed frequencies?
McGoat
Warren County Missouri
I notice it has the same NAC as Americus... is it a new Americus 700? I just found it tonight. So far I have only heard the Callaway County Sheriff department talking.
Voice Frequencies: 774.08125, 773.83125, 773.58125
Activity Summary - Decoder:p25 Phase 1 Normal (C4FM)
Network
WACN:BEE00[781824] SYSTEM:1CE[462] NAC:1C1[449] LRA:00[0]
Current Site
SYSTEM:1CE[462] NAC:1C1[449] RFSS:01[1] SITE:30[48] LRA:00[0] STATUS:ACTIVE RFSS NETWORK CONNECTION
PRI CONTROL CHANNEL:1-1772 DOWNLINK:773081250 UPLINK:803081250
SEC CONTROL CHANNEL:1-1812 DOWNLINK:773331250 UPLINK:803331250
STATION ID/LICENSE:
Neighbor Sites
SYSTEM:1CE[462] NAC:1C1[449] RFSS:01[1] SITE:01[1] LRA:00[0] CHANNEL:4-2751/4-2334 DOWNLINK:170387500 UPLINK:165175000
SYSTEM:1CE[462] NAC:1C1[449] RFSS:01[1] SITE:0D[13] LRA:00[0] CHANNEL:4-2855/4-2212 DOWNLINK:171687500 UPLINK:163650000
SYSTEM:1CE[462] NAC:1C1[449] RFSS:01[1] SITE:19[25] LRA:00[0] CHANNEL:4-2692/4-2163 DOWNLINK:169650000 UPLINK:163037500
SYSTEM:1CE[462] NAC:1C1[449] RFSS:01[1] SITE:2F[47] LRA:00[0] CHANNEL:1-1144 DOWNLINK:769156250 UPLINK:799156250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:1CE[462] NAC:1C1[449] RFSS:01[1] SITE:59[89] LRA:00[0] CHANNEL:1-1766 DOWNLINK:773043750 UPLINK:803043750 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:1CE[462] NAC:1C1[449] RFSS:01[1] SITE:5B[91] LRA:00[0] CHANNEL:1-1152 DOWNLINK:769206250 UPLINK:799206250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
Frequency Bands
BAND:0 FDMA BASE:851006250 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:-45000000
BAND:1 FDMA BASE:762006250 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:30000000
BAND:2 TDMA BASE:851012500 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-45000000 TIMESLOTS:2
BAND:3 TDMA BASE:762006250 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:30000000 TIMESLOTS:2
BAND:4 FDMA BASE:136000000 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-4600000
BAND:5 FDMA BASE:142425000 BANDWIDTH:12500 SPACING:5000 TRANSMIT OFFSET:5260000
BAND:6 FDMA BASE:145320000 BANDWIDTH:12500 SPACING:5000 TRANSMIT OFFSET:-1600000
BAND:7 FDMA BASE:140115000 BANDWIDTH:12500 SPACING:7500 TRANSMIT OFFSET:3465000
BAND:8 FDMA BASE:139575000 BANDWIDTH:12500 SPACING:7500 TRANSMIT OFFSET:3885000
BAND:9 FDMA BASE:137277500 BANDWIDTH:12500 SPACING:7500 TRANSMIT OFFSET:900000
BAND:10 FDMA BASE:136006250 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:-4600000
wbloss
Human
Joplin MO
Kingdom City 1-48 was a non-template older site; it looks like they have reconfigured it to be template "k" in the system of standard templates. Look for signals on the following freqs:
1k773.08125803.08125
2k773.33125803.33125
3k773.58125803.58125
4k773.83125803.83125
5k774.08125804.08125
6k774.33125804.33125
and bold is what you have so far. Let know so I can change the database
McGoat
So far I have not seen anything on 774.33125. Lots of activity on the other 3 frequencies though. 7 out of 8 MOSWIN control channels that I can receive from out here only use 3 voice traffic channels. Gasconade is the only exception.
GTR8000
NY/NJ Database Guy
BEE00
Motorola ASTRO 25 systems normally have one frequency per site designated for BSI and/or primary data channel, so it may not be used for voice traffic unless absolutely necessary. In this case I suspect 774.33125 is the BSI channel as it's the highest frequency at the site. Normally the highest or lowest frequency is the BSI channel, which is automatically "protected" and will be the last used for voice traffic.
wbloss
Human
Joplin MO
I don't know re the Rich Fountain update, but it is entirely possible that it reports a neighbor of 3-63 and no one has found the site yet to add it to the database.
nd5y
Wichita Falls, TX
Yeah that's what I meant.
The known sites in the db end at 3-56 so maybe there are several new ones in in the SE part of the state (RFSS 3).
KA0KDW
Polk County, Mo
On the MoSWIN 700 site Chanel 6 and 2 are the last 2 to be assigned to voice in that order. Channel 2 as it’s generally the secondary control channel should channel 1 go down for some reason. Channel 6 as mentioned is the BSI. And if you listen on analog you should hear a CW (Morse code) ID every 30 minutes.
