rbritton1201
Captain1201
- Joined
- Jul 27, 2020
- Messages
- 407
I notice on my scanner that when the scanner scans through MOSWIN towers, there is fully deflected signal bar at all times displayed on some MOSWIN towers but no carrier. I assume that the fully deflected signal bars without carrier are from MOSWIN towers that are apparently in range. I assume when the scanner scans over other MOSWIN towers that don't display a constant signal bar on the scanner, that those MOSWIN towers are not within range.
What I am not used to seeing with respect to MOSWIN is that from analog systems you only see a deflected signal bar when there is a carrier transmission. But, some MOSWIN towers on the scanner display a fully deflected signal bar on the scanner's display at all times, like you would experience if there were a continuous open key were they analog towers.
So, admittedly not really knowing exactly how this technology works, it appears that MOSWIN towers in range are constantly transmitting. Of course, the analog frequencies display signal only when there is a carrier, and that makes perfect sense. I'm trying to understand the technology a little better, and making uninformed assumptions as to what I'm seeing on the scanner with respect to constant carrier from some MOSWIN towers.
