Mot Type 1 Format in RR DB
kilowa22
Oregon
I'm try to understand Type 1 programming settings used by RR DB.
ARINC (O'Hare International Airport - Chicago) Trunking System, Chicago, Illinois - Scanner Frequencies
Code:
System Fleetmap
Type	B0	B1	B2	B3	B4	B5	B6	B7
Mot	A 	A 	B 	B 	M 	M 	D 	D
TT	S1 	S1 	S2 	S2 	S12 	S12 	S4 	S4
What do the Abbreviations Mot and TT mean? What does Type B0-B7 mean?
In the notes section for this system it mentions a possible alternate setting for Uniden Radios.
Code:
Uniden Custom Fleet Map may be:
0 1 2 3 4   5  6  7
1 5 2 2 12 12 2 4
This leads to confusion on what Fleet Map Needs to be programmed for this type I system.
mciupa
Canadian DB Admin
Moderator
Mot= Motorola radio, use the alphas in those blocks if you are using pro gear
TT= Trunktracker, program your scanner with the S numbers listed.
The "B" 's refer to the blocks of the fleetmap that the alphas or the "S" numbers are assigned to.
Not everyone owns Uniden products, so program the appropriate codes for your model.
