Mot XTS3000 800 Mhz CODE PLUG hexedit help!
rbluesky
Hi All
Well no I didn't save the original code plug Yeah I know !!! So I went to Code plug super and there is a 800 Mhz cp that i downloaded !
OK
so I tried to hexedit the codeplug for the radio i have , Changing the SERIAL number in the cp I download ! and make sure i have the correct CHECKSUM
took a while to GET the correct check some ! Got the correct checksum and It STILL WOULD NOT LOAD Error corrupted Header !
OK now your GUNNA say it's the flash code issue OK here my question can I hexedit those numbers to into the code plug
There's got to be a way to hexedit the CP to be accepted Can anyone help or ideas
the Original CP got corrupted when i made one change add a conventional freq, IN the Original CP all trunking was greyed out BUT Astro mode was not no encryption board kinda weird no trunking Here's the flash code 5000040000005 model H09UCF9PW7BN
the display is good the controls are good scrap on the display on the but still readable ! Ron
rbluesky
Yeah Kinda wasting alot of time on this I'll try sell it on the BAY
ElroyJetson
3000s are so cheap you can get them if you just ask nicely for one. No reason to put real effort into one at this point unless it's just a personal challenge to overcome a problem. Which I totally get. Sometimes the point is to prove you can outsmart the problem.
But if you just want something to work, pitch that radio (it's not like it'll be worth even its shipping cost) and get another one. And THIS TIME, READ OUT AND ARCHIVE ITS ORIGINAL CODEPLUG!!!!!!!!!
