With Freescan, read your radio, then CTRL K, then auto select. You should see one with a check mark. If so send this back to the radio. If you didn't see 1 checked, highlight the system that you want asigned to 1. It is BLUE now. Then on the right, you see find free, 1 should show upo, or you can assign 1 in the quick key block. now ctrl k again, auto select, then send this back to the radio.
