jimthehamnut
Hi,
Newbie to programming the vx2100-G6 using CE-82 software on Win10 Pro platform and FTDI chipset cable. Cable is working fine and so is the software (Version 5.01) however when programming for use in the uhf Ham band I set each channel for wideband but after downloading to the radio, all channels are changed to Narrowband. I am supposedly using the EXP (export?) version and not the USA version according to the download of the software (CE82_Setup_EXP_5_01_wide.zip). I understand the USA version will not allow WB programming and my software is acting like it IS the USA version. (See attached before download and after download pictures below). By the way, I have unchecked the SC column in each channel as I do not want to scan them. I have also added the TOT on all channels as I do not want to transmit longer than three minutes for each channel.
As you can see in the "before download" picture all channels are set for W5. (What's difference between W5 and W4?)
After download, you can see the channels have been automatically changed to narrowband. I have tried to answer both YES and NO in the little pop up as seen in the "before download" picture with no change on the results. All channels go to Narrowband. Is there something I am doing wrong? Is there a setting in the software to change this? I really need to get it to allow WB for each channel. Any help would be greatly appreciated.
Thanks in advance,
73
Jim
BEFORE DOWNLOAD PICTURE
AFTER DOWNLOAD PICTURE
Thanks in advance,
73
Jim
