MotoNet CP+ - KC/St.Joe
KCoax
I updated the Unidentified Wiki with my current KC ZOO and LifeFlight Eagle list. In regards to the zoo it sounds as if there are groups for building, exhibits and janitorial for Africa side. The other zones seem to be grouped together for the same type of channel line up. Needs more monitoring for accurate channel names.
KCoax
No. They're not encrypted. They also have 3 or 4 other talkgroups on the system that are strictly used for alerting crews at the Chillicothe, Odessa, and Harrisonville bases. Once the aircraft are up, they usually switch to the 31842 MARRS talkgroup or a satellite communications system. I'll try to get in touch with one of my contacts there to see what I can find out.
Over on MoKanscan.net they have a pretty cool LifeFlight wiki with pictures of the birds.
wbigcount
Kansas City
Just for info 6101701 is not KC streetcar its Express Tow, Platte City, Unidens have a bug with DMR where it will play the wrong audio on a talkgroup randomly.
6109101 KCSC 1
6109102 KCSC 2
6109103 KCSC 3
So far in all of the talkgroups I have identified they are never split up and why would they be.
mwjones
Frisco, TX
Just got back from two trips to Kansas City, and spent the last 2 days going through audio recorded. 37 newly identified talkgroups submitted, 11 talkgroups updated. All have been submitted to RRDB and will be live as soon as the DB Admins get them processed.
Of course I forgot to look at this thread, and missed submitting @wbigcount's report of the Streetcar and Express Tow. I'll go back and re-listen to that talkgroup (I skipped it because it was considered identified, but I have hundreds of recordings) to confirm, and will submit a followup.
I'll update the Wiki page in the coming days.
mwjones
Frisco, TX
Unidentified Talkgroups Wiki has been updated. A couple of notes:
6115101 thru 6115106 will be in the RRDB as "Concrete Delivery" and "Rock Hauling" I suspect it is a combination of Fordyce, Century or Ash Grove Cement (they're all owned by the same parent) and some research could probably confirm that.
6119601 will be showing in the RRDB as "animal control" I suspect its the Humane Society, but could also be the SPCA. Again, some research could probably confirm.
I have no travels back to Kansas City planned for a while, so that's it as far as updates from me for now.
wbigcount
Kansas City
6119601 KC Pet Project who took over for Kansas City Animal control
And here is what I have for 6105101-6105106 Not 100%
6105101 Plant 1 Geiger Ready-Mix Leavenworth
6105102 Plant 2 Geiger Ready-Mix KCK 4303 Speaker Rd, Kansas City, KS 66106
6105103 Plant 3 Geiger Ready-Mix Liberty Church Road.
6105104 Plant 7 Geiger Ready-Mix Olathe S38
6105105 Plant 8 Geiger Ready-Mix Lees Summit 150 SE Stuart Rd, Lees Summit, MO
6105106 Geiger hauling Ch Concrete Heading to Leavenworth Plant
mwjones
Frisco, TX
Good sleuthing @wbigcount - once you've got them confirmed, you should submit those to the database. My updates are still pending (one admin accepted 3 of my updates from around the KC Metro, and they're all still pending, anywhere from 5-10 days, while most of the others were done by other admins in 24-48 hours).
mwjones
Frisco, TX
Looks like most of my updates (with the exception of the Kansas City Zoo) are now live. The admins did a little reorganization work from what I submitted, but its all there.
scannerowner
NW Missouri
Looks great! As far as Life Flight goes, are those talkgroups dispatch for each helicopter? I'm assuming the radios affiliate with each site like MOSWIN, but can be wrong. I don't really know how these DMR trunked systems really work.
mwjones
Frisco, TX
Not sure on LifeFlight, but yes, the radios will auto-affiliate with whichever site has the strongest signal. That is part of the reason that you'll see the DSDPlus Network Repeater Map in the Wiki, that is an administrator pushed OTA update to all the frequencies and LCN's (usually when they add a new site)
KCoax
Three new sites:
Site 153-53
LCN = 1 TX = 463.21250 RX = 468.21250 DCC = 4 CC
LCN = 2 TX = 461.88750 RX = 466.88750 DCC = 4 CC
LCN = 3 TX = 461.41250 RX = 466.41250 DCC = 4
LCN = 4 TX = 464.58750 RX = 469.58750 DCC = 4
LCN = 5 TX = 454.62500 RX = 459.62500 DCC = 4 CC
Site 153-54
LCN = 1 TX = 452.65000 RX = 457.65000 DCC = 6 CC
LCN = 2 TX = 451.83750 RX = 456.83750 DCC = 6 CC
LCN = 3 TX = 452.17500 RX = 457.17500 DCC = 6 CC
LCN = 4 TX = 454.63750 RX = 459.63750 DCC = 6 CC
Site 153-55
LCN = 1 TX = 463.63750 RX = 468.63750 DCC = 3 CC
LCN = 2 TX = 461.38750 RX = 466.38750 DCC = 3 CC
LCN = 3 TX = 461.63750 RX = 466.63750 DCC = 3 CC
LCN = 4 TX = 451.91250 RX = 456.91250 DCC = 5
LCN = 5 TX = 452.17500 RX = 457.17500 DCC = 3
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Three new sites:
Site 153-53
Site 153-54
Site 153-55
153-53 - WQYA823 - Chapel Hill MO (LaFayette)
153-54 - WQMY409 - Higginsville MO (LaFayette)
153-55 - WPWQ761 - Iconium MO (St Clair)
Of course, those can't be added to the database just based upon a network repeater map and will require somebody to confirm they are actually online.
Thanks for submitting that!
Mike
