XPR Motorala XPR 3500e programming to Kenwood NX-340U16P
MoeNasser1302
I have 2 radios. The Motorola XPR3500E and the Kenwood NX-340U16P. I want to know how to program them to the same channel. I've seen that it must be analog. I have both programming cables and both programming softwares needed. I programmed them to the same frequency but when I talk on the Kenwood or Motorola it'll either flash green with no sound or play static. I don't know whats wrong. I need help.
EuropeanUser
/\/\ember
First of all, make sure the frequency is legal to use.
Second, make sure the same channel width and subtones are programmed into both. No sound and same frequency does indicate that the squelch doesn’t open.
Do you have the same frequency programmed for transmit and receive? Are subtones enabled on any of the radios, and if so are they set to the same tone?
Start there and see what you find.
