I'll have to take mine into Cleveland (Simulcast) the next time I go and see what it sounds like with headphones...
If Cleveland isn’t 3600 you won’t have either LSD or phase noise.
When I had a SmartZone system in my area I heard the low speed data on the voice channels on every scanner I had. It sounded like "chugga-chugga-chugga" and when the call ended it sent an end tone "Brrrrrr".When I put a set of headphones on my ears (connected to my SDS100), I'm hearing what I've seen called "thrumming" or "motorboating" sound (to me
Thanks Ubbe...Some scanners has a high pass audio filter at 250Hz to suppress any sub tones but it seems that some overtones from the LSD are still heard. SDS scanners, and perhaps others, disable the high pass filter during digital calls and it could be some issues or a bug when you have digital talk groups mixed with analog in your system if you only hear the LSD signaling in some of the calls.
Foolish humans!there could be a weird RF pick-up from the ground wire on the headphone.
humans ae also called 'stray capacitance to ground'.
i would say try computer speakers, but the same thing might happen, you could still try it though.
Yes.Are all those the same thing (WRT the issue I'm having?)
No, it's constant throughout the transmission.Is this noise you are hearing a constant pattern that changes about 1/2 second before the voice channel transmission stops?
Just to update... My much cheaper $5 headphones, with a low-end frequency response of 80Hz arrived. And they help a lot. If I didn't know that the thrumming was there, I probably wouldn't notice it at all. It certainly isn't turning my brain to mush as quickly 🤪. I haven't had a chance to wander around much to see if it's a location issue.
So, basically, Low Speed Data is evil and must be destroyed? 🤪
Real radios are designed to filter out audio frequencies below 300 Hz so you can't hear low speed data, and other low level low frequency stuff like DCS or PL tones. Scanner manufacturers never did that.So, basically, Low Speed Data is evil and must be destroyed? 🤪
