Seems like it's not necessarily the SU sending on two tgids at the same time, more of a RFSS ability (albeit normally coded as a regroup)
That's how multi-select works (or rather, this crappy form of MS). To be clear - no, I'm not suggesting the radio is transmitting on two repeater inputs at once. My guess is the split into two repeater outputs happens at the controller.
Normally multi-select is initiated from a dispatcher - either on a proper console (like you'd see inside a 911 call center) or as just another subscriber unit (as a backup when the main call center is down for maintenance or for departments running on a tight budget).
Let me back up a bit.
@boatbod,
@GTR8000 and
@DSheirer I think are very familiar but I want to state a few things so others can follow along. Setting aside telephone patching or ISSI linking, we have three kinds of patches.
- The normal patch where all radios joined/affiliated on subordinated groups talk to and listen on the supergroup until the patch goes away.
- The mutli-select patch. All radios joined/affiliated on subordinated groups listen on the supergroup but continue to talk on their respective subordinate groups. This allows the dispatcher to talk to multiple groups at once but also allows the members of each group to talk among themselves.
- Last is the crappy form of multi-select. The key trait is multiple simultaneous calls with the same speaker but differing audiences.
The snippet shared by
@DSheirer above appears to be an example of #3. The only advantage I can imagine is #3 may be faster to set up compared to #1 or #2 on some consoles. That said, I've never seen an ordinary subscriber initiate #3. Either this is a dispatcher radio / console or someone found and enabled a very obscure feature inside the RFSS.
It will be fun to see where this goes.
If you want to give someone nightmares - imagine a combination 1+3 or 2+3 above.
