Motorola 16 Pin Radio - Use with Zello
rockinromac1
Southwest Harbor, Maine
Hello all, I'm trying to setup a 16 pin Motorola to work with Zello. I'm trying to figure out if I need to connect the PTT wire from the connector to something from the computer to make it transmit or if the radio will transmit when it hears audio through the Mic Audio. Thanks for any help!
kf8yk
The SM50 does not support VOX (voice activated) transmit, even if it did VOX is not the recommended method of PTT control.
You'll need a Zello radio gateway between the radio & the PC.
rockinromac1
I wouldn't recommend that unless the budget allows.
A SignaLink with the correct interface cable is a much cheaper solution that would more or less offer the same capability. As long as you have the radio, PC and SignaLink grounded properly it will work fine.
Looks like we are going to be using a SignaLink, ill let you guys know how it goes.
rockinromac1
Morning all, Got the Signalink setup. Having a few small issues:
Audio coming out of a radio listening to the transmission from Zello is quiet, when we try moving the jumper to increase the audio output, it gets distorted.
Anyone have any ideas?
nhfdcadet
New Hartford, Ct
I used a Roxitek gateway with ZelloWork, connected to a CDM750 and an Intel Compustick, as long as it has internet, it works great
BigLebowski
Piedmont NC
I would like to tie one of these network radios running android into a radio and cut out the computer entirely.
Floridarailfanning
East Tennessee
That did help with the volume, although the sound does get distorted/muffled when increasing the amplifier.
Did you reset the jumper? Have you adjusted the TX knob?
Not sure how you could do that without building some kind of custom interface.
Uplink
Los Angeles County
I do a Zello interconnect with an Echolink R-1 controller, they are about $55 bucks on fleabay including a 16pin Motorola board.
tempestuous
Rhode Island
Uplink,
I'm trying to do what you are, I have a R1, zello work and a Motorola CM 300. Can you advise on the CPS settings? I can't seem to get it to work properly.
a417
what CPS settings are you looking for? the pin settings?
tempestuous
Rhode Island
Yes pls. I'm using the commercial series cps I just can't figure out what settings for the accessory connector. The instructions with the R1 unit mention pin 3 etc.but the CPS only shows me pins 2, 4,6, 8 etc.
Thank you
