you can use any of the addressable pins you like. The pin number does not matter if you are making the connections/cabling yourself, you can just pick what ever pin you would like. The functional interconnect is more important than the actual pin number. If you are using a ready-made/off the shelf item to connect the two, that would make the numbering more important.
