Motorola 3.5mm Audio Jack adapter problem
AZ_chris
Glendale, AZ
Hi guys,
I got the 3.5mm Audio Adapter jack (with the PTT switch) for my Jedi radios. However, whenever I insert a standard mono listening earbud, all I get is the "not programmed"-type tone from it.
What's going on?
cmdrwill
So Cali
A mono plug will key the transmitter on most radios. The correct 'plug' for Jedi series adapters is the 3.5 MM threaded 3 conductor.
