Motorola 800 mHz TFL1252A specs?
Rfsolutions
I have a 70 watt TFL1252A power amp. I'm using it for a research project and need to know the following. I have no schematic or manual so I need to know how much power input is needed to produce full power out (I'm guessing 5 watts)? Also, what is the supply voltage (12 or 24)?
Also, are any bias voltages needed to turn the amp on (it looks as though a keying relay is in the circuit)?
Thanks in advance!
