Motorola antenna. 800 mhz
I have the 6 or 7 inch thin whip for 800 mhz. And the big dipole antenna with the little tip on end there supose to be any difference in tx or rx
Sent from my LG-H343 using Tapatalk
MSS-Dave
Generally Central Florida
The shorter whips are actually dipoles. The longer antenna you refer to is an elevated feed dipole. If you are in a weaker signal area or if you wear the radio on a belt clip or holster and use a remote speaker microphone, you will have MUCH better performance with the bigger one. Of course a disadvantage is the thing sticking in your armpit and less flexibility.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Ok the longer antenna so stiff id be afraid of breaking the connector in radio i use it in a radio at home only i wouldnt use it to carry around any where.
I've used both on the Motorola MTS-2000 and XTS-2500's.
I could never tell the difference in performance between the two, at least no in any of my usage.
The stiffer antenna was a problem when sitting in a vehicle with the radio on my belt.
I never broke an antenna connector with one, but I don't think it would be impossible to do.
