Motorola antenna
GearJammersc
SC
Im sure I have asked this before What is the advantage of the NAF5039 dipole vs NAF5037. I have both antennas I really do not see a difference in reception. Only advantage I see is the dipole doesn't bend at all. The diploe seems to be more of a nuisance than any thing.
R8000
Low Battery
The elevated feed design came out with the STX series back a long...long time ago. The idea was to get the actual antenna part up and above your head when holding the ht while using it. Years ago I had a STX with the dipole and normal antennas, I also saw no difference between the two.
mlindler
Analyst of 1's and 0's.
Fountain Inn, SC
The NAF5039 on the old Type II systems had its advantages in fringe areas and in thick walled buildings. We noted a marginal increase in clear (analog) coverage using the Dipole antenna. I'm not sure how well they would perform today in a Simulcast Phase I or Phase II P25 system with the multi tower (saturated coverage) approach. As a side note, if you cut the skirt off the bottom and attach it to a Unication G4/G5 the coverage is phenomenal. Just a pro tip. :cool:
GearJammersc
SC
I see lol the antenna doesn't fit on the xts 2500 as well as the xts5000. I was just curious seems like i got a collection of those dipole antennas around. They do work just thinking electrically it work better.
mlindler
Fountain Inn, SC
Weird, I do have one on my XTS5000. Fits perfect with the skirt. Good Luck! :)
MTS2000des
5B2_BEE00 Czar
That was true on our legacy Smartnet II simulcast system. All the STX821s and MTS2000s were ordered with them. When I first got on with my agency, I had to do an inventory of all subscribers. I found boxes of the 5039s. Sadly, as most Motorola antennas seem to suffer, most were dry rotted despite being kept in cool (65 degree air conditioned server room in a dark cabinet) place.
I first put one on a few 5000s while we were doing testing of our new Astro 25 system and noticed no difference in RSSI or BER between that and the 5/8 wave whips that came with the 5K.
GearJammersc
SC
I tried the naf5042 1/4 today it makes the signal on my 2500 go way down. I wander if the antenna for the apx radios that are smaller would work better?
