Motorola APX 4000 M1 Battery Indicator
KF5YBV
Lohn, Texas
I'm having a little trouble with the battery indicator to appear on my APX 4000 screen. I recently bought another IMPRES battery (2800 mAh) and I already have (2300 mAh) IMPRES battery. When I put the 2800 mAh battery in the radio, It does not show a battery level indicator, but when I put the 2300 mAh battery in the radio, it does show a battery level indicator. Is there a way to correct it to where the 2800mAh battery shows a level indicator?
riveter
MD
If it never shows an indicator with that particular battery, it might be an issue with the IMPRES firmware in the one battery. Does it have any issue charging or reading data in the charger?
KF5YBV
Lohn, Texas
Has no issues charging or reconditioning issues at all. The battery lasts as long as it should, it"s just not showing up on the radio screen.
riveter
MD
Weird. I think every time I've seen such an issue it's been a problem with the battery itself - either a bad cell (and it starts flashing in the charger too) or bad firmware (and it won't read in the gang reconditioning charger).
