Motorola APX7000 or Harris Unity XG-100P
Which radio do you like the best?
  • Total voters
    20
  • Poll closed .
PACNWDude
Harris Unity for analog mode mostly.
I have to admit, In my case I use a Harris Unity radio to be interoperable for VHF,UHF and 800 MHz bands. However, these are often used in analog only mode.
My biggest complaint is that this radio does not do AM. Often times, I need to contact aircraft in AM mode and then a command post on UHF, or ground crew on VHF, with Coast Guard on 800MHz.
Then there is the durability factor. I do not baby my radios, and my Harris Unity does not seem as durable as my APX. If the Harris did not have a metal belt clip, I would probably carry the APX instead.
It is nice to have three bands in the radio, and I have used the GPS as well. This is where it does better than the APX7000 for me. When my company was debating new radios, they were replacing Motorola equipment. So the logic was to buy new Motorola equipment. We have ended up going MotoTrbo, with a few people like myself, buying Harris radios for our personal use.
We use a lot of Telex, Gai-Tronics and other interface gear to patch between bands, so multi-band was not important.
Personnel in the field just want a dual band VHF/UHF handheld so they are not carrying two radios, or needing a patch between the two. But at $4-6 to get that from Motorola, the patch gear is actually cheaper.
I know of several companies in the oil and gas industry that would gladly buy thousands of VHF/UHF Motorola radios, if they were IS FM rated, and priced in the $2-3 range. That price point can be justified a lot easier than $4-6.
gesucks
Our Nation's capitol
Thunderknight,
Sorry for questioning you, but you know how some of these online threads can get.
The radios are running XGPRO1A38, RPM is current. Programmed as you suggested....button just gives a beep. Perhaps there is a bug in this firmware version that will be corrected the next time around? Also this firmware does not do Type 99 decode. The scan has bugs where it locks up scanning that Harris knows about and is currently working on a fix.
XGPRO1A38 was beta firmware. Try with the current XGPRO2A14
Thunderknight
Bletchley Park
Thunderknight,
I tested it on a 1a38 radio today and it worked there for me. Something I thought of but didn't have time to test. Under scan options in rpm, what is your scan list set for? Ours is set for user programmable. Is yours set for fixed? Maybe that negates nuisance delete?
Peoria, IL
I didnt want to vote on my own poll. But if I were to choose a radio I would choose the Motorola APX7000. I would choose it because it has exceptional audio. It can do pre P25 systems and current P25 systems including phase 2. I dont really dont need that many channels in a radio like the Harris. I really only need 2 bands anyway. My two bands are UHFR1/700/800MHz.
