Motorola APX8000XE
hunmill
After receiving Motorola APX radios for our FD from our local communications department we set up favorites in the dynamic zone which was left blank by the original programmer. This was done by selecting ZnPr and going through the obvious following steps. Now when trying to edit any channel in the favorites zone, ZnPr is not displayed on any of soft keys even after scrolling over. Is there another way to enter programming on a dynamic zone or are we stuck with the channels currently in this zone?
bcooper8441
morrisville,pa
was the programming changed since getting the radios? If the communications department changed the programming they might have made that zone as a, home zone where all of the channels you may use are in there. My suggestion is to either ask the radio techs about it or check the programming in your radios. whichever sides programs your radios
gary123
Not much help but a good suggestion for programming. The radios should follow a basic programming pattern. IE convention/trunked personalities in sequence for zone 1. Then the personalities for zone 2 etc. This makes navigating the zone configuration much easier. The programmer can then position everything easily to suit the end users requirements.
rescueman433
znpr should still be there. There is a good chance that znpr was not added to both the conventional and trunked menu items during programming. Try finding znpr on each type of channel that you added to the dynamic zone, hopefully you have some of each in there, trunked and non trunked. Feel free to pm me as some of the responses don’t seem to understand what the dynamic bank is for, user defined zone.
dickie757
Wired
Out of range
What op is talking about has zero to do with cps'ing his own radio. Radios we install into super trooper's tauruses need to have favorites set up, too. It is part of the tech/trooper initiation into their new rig. It is fully on the end user to change it as they see fit. Since I am not the end user or a state tech, I dont know the details.
Reach out to your radio dude to get the info you need.
