Motorola ASKRemoval Tool
dfb8085
Cumming, Ga
I am trying to find the ASK Removal tool. I see people talking about it but havent been able to locate it.Can someone please point me in the right direction?
Also I understand there is a way to hex edit the codeplug not sure which file but the instructions say go to block 10 offset 48 and change the hex decimal from 0010 (4) to 0000 (zero) which the radio sees as a donot check for a ASK key. Now that I have shared that does anyone know how to hex edit a file? I can do the change I just need to know in which file and how to locate block 10 offset 48. anybody direct me to the correct file and location?
Thanks for any and all help and direction trying to fix this problem
Reconrider
Inside the Galaxy
Radio Galaxy
More importantly, what radio codeplug are you trying this with? It doesn't work but with only a few radios to my knowledge
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The instructions you have are for a software tool called Flashzap which is not for discussion here. You'll have to find a version of the ASK removal tool.
otobmark
NC
You can remove or "unprovision" your radio of it's ASK option and they Key will disappear with it. If you need to install an ASK in the future you will have to reinstall ASK provision.
flagship2023
How would one do this? Is it an option in cps?
