Motorola astro 25 cps announcement group
videowebhd
xxx
Motorola astro 25 cps Announcement Group
Hi everyone! I'm a newbie to the Motorola APCO P25 trunking . I got the Astro 25 cps R20 with a XTL2500 radio and in Trunking personality " Announcement Group " how can it be defined . Where i can found the good ID i need for every talkgroup i want to add .... for Exemple i got a Talkgroup with 3 id 4700,4719 and 4758 which Annoucement group i need to select for that .....
i Hope im clear ;)
Thanks in Advanced !
mikewazowski
Staff member
Forums Manager
Oot and Aboot
You need to talk to your system administrator to find out if they use an announcement group and if so, what it is.
videowebhd
xxx
I cant contact them. i just need to monitor this network and i cant contact the admin, But i know they use announcement group.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Looks like you're trying to listen to this system: http://www.radioreference.com/apps/db/?sid=5492
Can I ask why you have a Unit ID entered if you are only monitoring?
Unfortunately, the system admin can select any talkgroup as an announcement group. You'll need somebody local who might know it or you'll have to contact the system admin (who is probably reading this thread and will likely try and brick your radio) or you'll have to setup some sort of monitoring program and see if you can figure it out for yourself.
