middleofAKTB
I have a Motorola Astro Spectra that I purchased for programming practice and the radio will not receive or transmit at all. I cloned this radio with another Astro Spectra (original radio Rx and Tx just fine). After cloning the radio i turned it off and back on. It self tested just fine with no error codes. However as soon as I use the PTT it will not transmit even though the MDC Side tone goes off and the red Tx lights up as it should in normal operations. I also tried to test it's receive and I get no audio or a BUSY yellow light.
I went through the entire program and went page by page to compare the original programming and found nothing that would have inhibit the cloned radio from normal operations. The program has nothing but conventional channels (no trunk channels what so ever) and this radio has no encryption capability. I checked the secure and everything is turned off. I'm completely stumped and have no idea what to check or how to troubleshoot past this point. I'm starting to wonder if it's the radio itself ie bad Tx and Rx board.
If anyone has any suggestions I would greatly appreciate the coaching. Thank you!
