Motorola Astro Spectra VHF Out of Band
hawket
I was wondering if anyone knows how to modify the CPS Software to allow for out of band programming on a Motorola Astro Spectra Radio. The software will allow me to program a J SPLIT, but I would like to program a K Split which would be out of band.
W0JJK
Just type in the 145.XXX in to the conventional personality and when you go to program codeplug in radio, the CPS will warn you out of band operation. Click OK and it will program them into the radio. I have done this to a couple different VHF Astro Spectras and works like a champ.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
145.XXX won't be a problem on a J split. I assume he's trying to program above 162MHz.
Check p25.ca. They've got quite a few hacks for the ASTRO CPS.
cmdrwill
So Cali
In the ham 144 to 145.999 the P25 does not work properly due to some coding in the radio. Conventional works good in that part.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I'm confused as to what split the OP actually has. p25.ca also has a procedure to fix the tuning values so the radio will work properly out of band.
hawket
It was my understanding that there was Software CPS hack which would allow you to program Out of Band. I think the Spectra J split is 136-162 and the K split is 146-174. The radio is a K split radio.What I was wanting to do was program the radio in the 142 range for Digital Trunking. The radio right now is programmed with out of band and needs to be changed because just not happy the way its programmed.(Yes it currently doing digital trunking) I have read and read and just can't figure it out.)
MUSTANGMAN
HUNTSVILLE ONTARIO
I've been reading this thread and i downloaded Hex editor. I opened the code plug in it and i thought i did as recommended. I am using cps 5.03.00 . I was wondering if there was a way to get a more step by step of what to do. I want to program low split trunking in to a high split radio. Thanks
