To anyone looking to acquire commercial radio programming software:
I have a Motorola Astro xtl 5000 upon turning it on the radio displays fl 01-90 error code than immediately turns itself off. Any idea what's going on with the radio and fix?
Is it a remote mount radio (separate control head)? 01/90 is control head communications failure. If it is, ensure head and unit have power, head has ignition, and the control head cable is firmly seated. If it isn't, the control head flex connector inside the radio behind the head may need to be reseated.
Lucky you, I have been having the same problem with an O5 head dash mount. Have changed control heads, replaced ribbon cable, check internal voltages, and re-did some solder joints.....nothing. Sad, such a good radio.
I know the Spectra and Astro Spectra could be forced to boot without a head. Don't know if it can be done with the XTL to check if it is the brick or head.
