motorola astro xts 3000 vhf
kb5vai
i have a astro 3000 model 3 ht. trying to program the radio.
how do i get the radio into program mode? site said to press and hold button above ptt. radio supposed to beep nd change display. nothing happens. trying to read with a panasonic toughbook, unable to communicate. trying with hp laptop and usb to serial adapter, same.
also can someone post a valid link to motorola xts 3000 program cable? ebay can get confusing so not sure if using right cable. have tried 2 different cables.
thanks
N4KVE
PALM BEACH, FLORIDA
There is no program mode. You just turn on the radio, & read it. It’s the same cable as the MTS2000. And many times, the USB to serial adaptor doesn’t work. So use a laptop with a real serial port, & get a ribless cable for $20.
kb5vai
Thanks. Sure enough searched ebay. One had 4pins on radio connector, 1 had all the pins on connector. Panasonic tough book has serial port, tried com 1 and 2, no joy. What speed does the port need to be at?
wgbecks
NE Wisconsin
The bigger question is, are you using the correct CPS program? Your CPS should be labeled Astro Saber & XTS3000. Then once you specify the com port upon the initial "Read" operation, CPS will initialize the port with the correct communications attributes.
Programming the Astro Saber & XTS3000 normally requires the use of the RIB and proper programming cable unless your have RIBLESS programming cable designed to work with the XTS3000 radio.
jaspence
Michigan
I use a cable from kawallmall that has a true serial connector and works well. I use Windows XP, 32 bit and have not had a problem with Motorola or EFJ older radios.
N4KVE
PALM BEACH, FLORIDA
Exactly what I use. XP laptops are cheap these days, & great for older radios.
Are you getting a serial port to be available in device manager when you plugin the USB to serial adapter? Do you see something showing up as COM PORT. Correct manufacturer driver installed for the USB to serial adapter? Click default port settings for now, 9600 8 none 1 none at thats my defaults with FIFO
jaspence
Michigan
My experience with 4 different usb to serial adapters was as bad as the kawamall is good.
The only USB to serial adapter anyone needs is the IOGEAR GUC 232. This has been listed forever in the official README. They've recommended this one forever. The correct driver must be used
NOTE: For computers that are not equipped with a serial port, radio communications may be
possible with the use of an off-the-shelf
USB to RS232 converter, such as the IOGEAR
USB to Serial/PDA Converter Cable.
