Motorola CDM 1250
Monstertails
I am hoping someone can help me out, I purchased a CDM 1250 On Ebay and I am able to connect to it and read and write to it but I am wondering if some one can tell me how to delete the channels that were stored in it from the previous owner? I have some experience with DMR code plugs but nothing with motorola programing. I was able to edit a few channels and add my local repeater but i want to know how to delete the other 54 channels that were set up. I am using motorola professional cps version R06.12.05. I am super new at this so if you could, just spell it out for me.
Thanks!!
Open each personality and there should be a red X on the bottom of the tab. That should delete them.
It might complain that they are in the zone/channel assignment (I can't recall), so you may need to go into each zone and remove each channel assignment there.
I'm sure you know this, but make 100% sure that you have saved a copy of the codeplug BEFORE deleting anything. Then save the codeplug again somewhere else. Having a fall back is a good idea, even if it has channels in it you don't want.
Monstertails
Awesome! Thank you so much! If I may just ask one more question, like I stated in my last post, I have been able to edit the channels to get in there the frequencies that I want. Do I need to set a different squelch if I’m using a Symplex frequency Versus using a repeater frequency? I know repeaters use the CTCSS tone but with the software I’m using it doesn’t give that option.
a417
You can set a different squelch setting (or none at all) if you are using simplex frequencies, everyone else you are trying to talk to will also need to have the same settings (or listening CSQ) to hear you.
It will entirely depend on your needs.
a417
OK I understand now CSQ can you tell me what the differences between TPL and DPL SQUELCH TYPE?
PL and DPL are signalling types that are well discussed on the forums here, and in the linked Wikis. The information is out there, it could be seen as a challenge to the reader to go find it.
