Hello All
Thanks in advance,
I'm good with most technology but radios elude me,
I have been currently running our scanner feed on a bearcat xlt60 scanner running through the headphones jack and it works but is terrible quality, I have a Motorola CDM1250 radio and would like to use this as a feed radio. It currently has a PC plug that is soldered to send the audio signal out when sound is being played (see below). When I plug this radio into our broadcasting computer the server reads offline as it doesn't see the audio signal unless there is chatter. Can anyone recommend the correct plug to buy for this radio so we can use it for broadcasting? The rear of the Motorola has a port labelled PC with two rows of ten pins on each row.
(Seeing below) - our old setup basically was a setup to send signal through rca to a computer in our dispatch room, the computer had a program on it that as soon as an audio signal was detected it would record the audio and save it as a file. This would give us a audio file for each transmission on our FD channel so we had a record of transmissions.
Motorola CDM1250
Model: AAM25KKD9AA2AN
TANAPA: IMUD6015B
Ver No: R05.04.00
Serial No:103TDLF8921
Server: win 7 64 running latest version of scannercast
Ryan
Thanks in advance,
Motorola CDM1250
TANAPA: IMUD6015B
Ver No: R05.04.00
Ryan
