CDM Motorola CDM1250 Scan Question
W3AWF
Chester County, PA
I’m having an issue that I can’t seem to find any information on. Currently programming a CDM 1250, I have programmed two different scan lists into the radio, however I can’t seem to find anything explaining how to switch between each scan list from the head of the radio. If anyone could shed some light on this issue it would be greatly appreciated!
brndnstffrd
CT
You cant switch at-will between scanlists. They are set per personality which scanlist will be used.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If you need the same channel (or channels) in more that one scan list, just create a second identical personality and assign each one to a different scan list. You might want to include something in the personality name that indicates which scan list it is connected to. Not difficult to do, just takes a little bit of organizational planning, and enough extra personalities. (Remember that the CDM1250 is limited to a max of 64 personalities.)
