Motorola CDM1550LS+ beeps when receiving traffic (only on 1 channel)
parkerd619
Camden NC
Hey folks,
I use the above radio for monitoring local radio traffic. I set it up a few years back with the correct CPS. For some reason, I set channel 1 to beep when the squelch breaks. It only beeps once. But, it gets annoying if the channel is busy.
I have been all through CPS and cannot figure out how to turn it back off. Does anyone have any advice?
Thanks a lot
scfd4
Zip tie technician
PA
Sounds like you have it set as a priority channel, without looking at cps I can't walk you through it but I'm sure someone else will chime in shortly. You can also use the cps help menu and search for priority scanning and how to enable/disable. Sorry I can't be more help right now!
parkerd619
Camden NC
I do believe you were right. I went into CPS and see that it was set to priority.
Thank you for your help.
a417
That was one of the more often "I want to enable this feature" that came back as "please turn that go****n thing off", a week later. The other one was the activity tone on the Whelen Cencom controllers.
