Motorola CDM1550ls+ programming software
danc107
Sayville, NY
Hello all, I was wondering if anyone knew where I can find programming for the radio above
Thanks all
Dan
n3obl
Ø
PA
google for waris software. Will come up in one of the links
a417
I am running windows 10, I have only found versions for older operating systems
Thats because those radios are now 20+ years old. You will find most success with a 32 bit OS. Think Windows XP or maybe Vista.
K2NEC
NA
Latest I was able to use is Win 7 64 bit. Anything newer and it won't work right.
LD723
Could try to run it with a different compatibility option os under properties for the program
BITT211
ELMA , N.Y
look at - Elite Communications - South N.J. on Ebay , they have software what your lookng for .
com501
Make sure you have a SERIAL PORT attached to your computer before you boot the program, otherwise it usually don't work.
I am running Win 11 64 bit with that software, no problem.
