Motorola CLS Radios
BigLebowski
Piedmont NC
Anyone know if there is a list of the frequencies/PL/DPL tones the Motorola CLS-series use anywhere? There seems to be 100+ freqs and at least 100 if not more tones. The radios I speak of are coming into use now at Target stores.
Thanks!
denseglow
They use the UHF business freqs there are 56 of them:
464.5000 UHF 1 BROWN STAR
464.5500 UHF 2 YELLOW STAR (Default Ch 1)
467.7625 UHF 3 J DOT
467.8125 UHF 4 K DOT
467.8500 UHF 5 SILVER STAR (Default Ch 3)
467.8750 UHF 6 GOLD STAR (Default Ch 4)
467.9000 UHF 7 RED STAR
467.9250 UHF 8 BLUE STAR (Default Ch 2)
461.0375 UHF 9
461.0625 UHF 10
461.0875 UHF 11
461.1125 UHF 12
461.1375 UHF 13
461.1625 UHF 14
461.1875 UHF 15
461.2125 UHF 16
461.2375 UHF 17
461.2625 UHF 18
461.2875 UHF 19
461.3125 UHF 20
461.3375 UHF 21
461.3625 UHF 22
462.7625 UHF 23
462.7875 UHF 24
462.8125 UHF 25
462.8375 UHF 26
462.8625 UHF 27
462.8875 UHF 28
462.9125 UHF 29
464.4875 UHF 30
464.5125 UHF 31
464.5375 UHF 32
464.5625 UHF 33
466.0375 UHF 34
466.0625 UHF 35
466.0875 UHF 36
466.1125 UHF 37
466.1375 UHF 38
466.1625 UHF 39
466.1875 UHF 40
466.2125 UHF 41
466.2375 UHF 42
466.2625 UHF 43
466.2875 UHF 44
466.3125 UHF 45
466.3375 UHF 46
466.3625 UHF 47
467.7875 UHF 48
467.8375 UHF 49
467.8625 UHF 50
467.8875 UHF 51
467.9125 UHF 52
469.4875 UHF 53
469.5125 UHF 54
469.5375 UHF 55
469.5625 UHF 56
They use the default PL and DPL tones for Motorola radios.
n1das
Nashua, NH
In the CLS series radios, all 56 frequencies are using "narrow" (11k0f3e) bandwidth and use Motorola's X-Pand audio companding system. X-Pand is always on and cannot be disabled.
I keep all of these frequencies programmed into a bank in every scanner I own. You never know what you'll hear on these frequencies, licensed or otherwise! Most acitvity from what I've monitored has been unlicensed. Motorola is using the bubble pack approach to market these radios similar to the FRS/GMRS bubble packs, except these are marketed towards business users.
BigLebowski
Piedmont NC
A google search has not yielded any results with a PL/DPL list. Specifically i'm looking for the following codes in the radios now that I have the frequencies.
54
50
62
68
72
79
Any help would be greatly appreciated!
R
Rayjk110
Guest
We use those for floor staff at my work.
The default "from-the-factory" frequency is 464.550 PL67.0
They all default to a 67.0 PL, no matter which of the 4 channels you are on. I know that channel 3 is 467.850. Not sure on 2 and 4.
Most agencies who buy them will never change the channel/PL tone as they either don't care, or because since they work fine out of the box, they just don't wanna dick with it.
All of the tones you listed are DPL.
n1das
Nashua, NH
54
50
62
68
72
79
Those codes are DPL codes. Codes 1-38 are for the 38 standard CTCSS/PL tones. Codes 39-121 are Motorola's 83 standard DPL codes.
The owner's manuals for many of Motorola's cheap business radios such as the CLS series and the XTN series list all of the tones/codes with the corresponding code #. I know they are listed in the XTN series owners manual. Surf Motorola's site and download the XTN series User Guide document.
Good luck.
n1das
Nashua, NH
54
50
62
68
72
79
From page 40 in the XTN series user guide....
Code #54 = DPL 115
Code #50 = DPL 072
Code #62 = DPL 155
Code #68 = DPL 205
Code #72 = DPL 244
Code #79 = DPL 306
Glad to help!
