Motorola Commandstar?
CDS-INC
Banned
just a quick question,
Can you hook and use a mobile radio into a motorola commandstar dispatch console, or does it have to be hooked into the repeater?
CCHLLM
The console doesn't care whether it's connected to a mobile or to a remote line input/output device to the repeater or base station so long as the input/output connections and programming are mutually compatible. To do that requires some sort of remote adapter and proper programming of the mobile unit as well as configuring the I/O of the console. Those devices are readily available through the console manufacturers, the radio manufacturers, and the aftermarket. I've personally done several installations that connected a mobile on a power supply to the console.
WayneH
Forums Veteran
Super Moderator
Your master site
Moved to the Motorola forum. CDS, please get in the habit of checking the forum and its description before posting in it. Thank you.
