Motorola CP200 Error
BlueDevil
WA
I have successfully programmed several Motorola CP200 VHF radios. While trying to program 1 radio I had an error and now I cannot read or write the radio. The error says that the codeplug is corrupt.
I have had a similar problem with the HT1250. I was able to force the original codeplug back onto the radio. Can this be done with the CP200 or is the only absolute fix to send it to the depot.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Brandon,
I had a similar problem with a CP200XLS. The programming cable was accidentally pulled before a write to the radio was complete. It showed ERROR on the screen and wouldn't do anything.
I fixed by it reading another radio (exact same model number) and then writing that known good codeplug into it.The software attempted to read the radio first, recognized a problem, repaired and then properly wrote the new codeplug.
Just note that it wasn't the factory original codeplug that I used to fix it; just a known good one.
Good luck with and let us know how it turns out.
BlueDevil
WA
I have tried that already but maybe I will give it a few more attempts. I have also tried cloning as well with no success. I just really don't want to have to send it in.
thassler
Tennessee
You may need the latest CPS software as the later version will try to do a corrupted codeplug recover when the earlier one will not. Seems like there is a patch you can also download from your MOL account that will recover certain firmware versions. Our jail uses CP200s and I remember running into the same thing a while back....
