Motorola CPS Error -113
wes63446
OCNY
I am trying to install my software on a new to me computer after my other computer crapped out on me, the motherboard went. When installing the CPS software version R06.01.00 i get the following error message: An error occurred during the data move process: -113.
I searched but the only answer I found was to close all programs and try again. Has anyone ever had a similar issue or know how to resolve it?
Thanks,
Ryan
crazyboy
NJ
Are you installing on a compatable version of windoze?
Sent from my VS980 4G using Tapatalk
sfd119
CPS does not work on 64 bit windows OS.
Manny
No where does he mention he is using 64bit.
Thanks,
Ryan
Ryan:
Try making sure your .NET Framework is up to date. Make sure permissions are not an issue (ie, make sure you're logged in as the administrator).
Try those things and get back to us.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Nowhere does he say he isn't! Just one more base to cover before going into a long list of try this or try that!
Manny
In message #3 of this thread, the OP wrote:
I am attempting to install it on XP
For the OP, which CPS is this?
FWIW, for starters, uninstall whatever you previously installed.. Presuming that you have a full copy of the CPS, try installing it again. If you have it in a ZIP file, extract the install set to a unique folder and then run setup from there.
