Motorola CPS ?
tcarroll4
What needs to be done after purchasing Moto CPS Dwnld to open open Analog on UHF XPR7550?
Thank's
rescue161
KE4FHH
Hubert, NC
Analog is automatically part of the XPR7550. You just have to create an analog channel. In your zone that you want to add an analog channel, you right-click on the zone and then select "Add" and under the drop-down list, you select "Analog." Then you just put in the settings that you want for that channel, i.e., frequency, tone, etc.
N4GIX
Hot Springs, AR
You may also need to obtain the 25MHz EID if you are planning to add ham analog frequencies to your XPR7550.
