Motorola CTS 2500 Battery Question.
N1SQB
Somewhere On Earth
I purchased a 2500 recently that is working flawlessly. It came with a used NTN9858C OEM battery. I’m getting about 8 hours on RX only mode. That tells me if I was using it to TX I would get half that or 4 hours tops.
So my question is, what is the highest OEM capacity battery available for the XTS 2500?
Manny
MTS2000des
5B2_BEE00 Czar
NNTN7335B lithium ion, rated at 2800mah.
FWIW the 9858's are old school NiMH, how old they are will last, brand new fresh date code they're good for a 12 hour shift at rated duty cycle.
Old, worn out after 2 plus years, expect about what you're getting.
What is the date code?
N1SQB
Somewhere On Earth
It says 1418 on the back of the battery. I guess it’s the 18th week of 2014 then. Yeah time to go. Thing is that if I switch to Lithium I have to get a new charger too no? This impress one probably won’t work, or will it?
Manny
MTS2000des
5B2_BEE00 Czar
if the charger supports lithium ion batteries, it should charge it, but you'll lose the IMPRES functionality and battery gauge. That being said, IMPRES single chargers for this series are dirt cheap, around $30 on Ebay, just make sure you get one that is V3.40 or higher for charging XTS2500 batteries. The version number is printed on the sticker on the bottom.
Your correct on the date code, 18th week of 2014, which makes it close to 6 years old.
N1SQB
Somewhere On Earth
I spoke to the seller I bought the package from. He said he upgraded the firmware on the charger to the latest and that it will handle lithium ion batteries. However he told me he upgraded it to vs 3.11 so I’m a little confused. There’s a huge numerical difference between 3.11 and 3.40
N4KVE
PALM BEACH, FLORIDA
They redid their FW numbering system. In the past, an upgrade from 3.9 would be 4.0. Now they just upgrade the numbers after the period. So since 11 comes after 9, that’s how it’s now done. Makes no sense, but who am I to wonder why.
N1SQB
Somewhere On Earth
Thanks for clearing that up. Now I get it..
Manny
