Motorola Desk Mic Connection to XTL2500 Accessory Connector
Bick
Madera, CA
I am trying to hook up a Motorola desk mic (RMN5070A) to the rear accessory connector of a dash mount XTL2500. I have determined the pin locations for GROUND (pin 14), AUX PTT (pin 16), and AUX MIC (pin 23).
On the desk mic connector itself, I have PTT on pin 2, GROUND on pin 5, and MIC_ HI on pin 7.
What I am trying to determine is where on the accessory connector do I connect HUB/KEYFAIL (mic connector pin 9) and GPIO (mic connector pin 10).
NOTE: I do not plan on using the HUB feature.
Thanks for any help,
Gray WA6BJY
littona
Super Freq
Council Bluffs, IA
Can't say I've tried to do exactly what you're doing, but I have a document that shows how to interface a radio over IP device to an XTL2500 accessory port. Maybe it'll help some? Here are the pins they used:
20 - SPKR+
26 - SPKR -
13 - Chan Act (COR)
25 - Ignition Sense (+12V DC)
23 - Mic HI
16 - PTT
15 - Emergency
21 - RX Filtered Audio
14 - Ground
Bick
Madera, CA
Sounds similar to what I have been able to find using a number of Motorola pubs, also. I think I am going to have to rethink my project but it will not be as pretty as my original plans.
Thanks for your response.
Gray
