Motorola Desk Mic Restoration
AerialEars
I have a Motorola desk mic, model TMN6017A. I'd like to get it usable and rewire it for my Kenwood TS-570. The mic element has E-4 stamped on back of it. I'm going to wire the PTT circuit to a couple of terminals on the transmit button that connect when the button is pressed.
Will this mic element work with the TS-570?
If not, can you suggest a mic element that would work and fit in the mic head?
Thanks in advance for your assistance and suggestions!
EWC_BDN
I'm pretty sure that is a dynamic mic. So it wouldn't work. what i would do is just take all the guts out of a kenwood mic and put them in the Motorola mic.
prcguy
Most Motorola mics, especially that vintage are designed to feed a carbon mic input. That mic is probably from the 1960s Motrac era and is probably a dynamic element with preamp circuitry that uses a bias voltage to feed the equivalent of a carbon mic input in the radio.
The TS-570 takes a dynamic mic and bypassing all the preamp stuff in the Motorola mic might work. Some radios also have a secondary mic input compatible with electret condenser mics and if the 570 has that feature it might work with the stock Motorola mic.
cmdrwill
So Cali
Some of those did have a dynamic mic element and the amplifier was in the base of the mic stand.
