Motorola DTR HTs
ke6ats
I'm curious about the actual average range of the various DTR series handhelds. I've seen/ heard that people have used them at Disneyland & such which would seem like the range is fairly decent. However, at my former workplace the IT folks tried to use them & told me that, in their opinion, they sucked. I was told by them "we can barely talk to each other from our office to the main lobby". That distance is about 1000 feet & their office was about 50 feet in elevation above the lobby's. Can any users of those radios clue me in? TIA
nokones
Sun City West, AZ
On flat terrain out in the open about a mile in a half at the most. This with 2 DTR700s. I'm not sure what the DLRs would do insofar as differences. The DTRs have better antennae.
KC3ECJ
I used them when I worked at Macy's.
They worked fine in that single floor store.
W6VVM
I have some DLR1020’s we use with the kids when camping. I’ve been really impressed by their coverage. We’ve had them work close to two miles away in the sierra nevadas with lots of trees in between.
We also used them once on a cruise ship. They worked from essentially the front of the ship to the back (~800 feet?) with 3-4 floors in between. I thought that was pretty impressive.
My biggest complaint (and I’ve heard this from many users in a business setting) is that users tend to cut their traffic off at the end by unkeying when they really need to hold the PTT for an extra half second. Seems like something Motorola could fix in firmware.
cubn
Search, Listen and Submit
Marion/Johnson County, IN
My experience has been range testing in a neighborhood. With the DTR650s with short antenna I got 0.5 miles but with the long antenna I got 1 mile.
Amazingly, the DLR1020s worked up to 1 miles with their small built in antennas.
I tried both while golfing by leaving a radio of each in the car and I did get the out of range bonk on both when at the farthest point on t.e course from my car. This course was quite wooded.
Wicho
Never never land
I have DTR700 and DTR600 units with long and short antennas, and DLR1020 and 1060 units too. They’re all phenomenal for what they are.
Range has just about always, in my experience, beat out 5W UHF simplex DMR, NXDN and analog inside and around buildings and urban areas. Have used them at many large school campuses and downtown San Diego, CA for a distance of many blocks (real downtown area with high rises). Surprisingly, they also perform better through lots of pine trees (use them in Truckee, CA and the surrounding area and mountains) than my 5W UHF and VHF in analog and digital.
I’m surprised your IT people had problems at 1,000 feet, but without knowing what was in between the two radios, my comment should be taken with a grain of salt.
PACNWDude
I have a couple of local school campus locations that use the DTR410's, with the short fixed antenna. They work great for a campus of about a dozen buildings with few other obstructions, up to three floors and about a five acre area.
Two that I have for personal use, well in the woods they do not work well, maybe a half-mile. I also have used them on a 212 foot steel ship, they work well between about three or four decks (of eleven - crows nest), but do cut out and will not transmit unless you have another unit in range (and similar programmed - custom Talk Groups in use). At my own work, metal office equipment, cabinets and pre-stressed concrete walls mean I get about a city block on range. The DTR410's tend to have shorter range than the DTR500/600/700/DPL series due to the fixed and short antenna.
Great radios though, that work well in office and ship type of locations. Even with a short and fixed antenna. But, they are limited in range and power output, but make up for discrete and relatively secure comms if you do not leave them defaulted on programming. (Many construction companies in my area of the country bought these and left them defaulted....saturating 900 MHz ISM band, trying to get away from the overly used UHF FRS/GMRS band).
ke6ats
Thanks for all the input from all of you. Greatly appreciated.
alcahuete
Southern California
Depends on which radio, where you're using it, etc., I have a whole fleet of DTR650 and DTR550 radios, and have had amazing results. I have gotten well over 20 miles here in the Socal desert. Ran out of road before I ran out of range...literally. Have gotten entire cruise ship coverage on pretty much every ship I've been on, and basically entire hotel coverage as some of the largest hotels in Vegas. Regularly use them while boating and routinely get better coverage than VHF marine, in areas of terrain.
In an urban environment or out in the forest or something, you're not going to do so great. You're not going to violate the laws of physics with these things, but they're just phenomenal little radios.
ke6ats
Right on. After all the replies, I'm thinking I'll give them a try. Thanks.
alcahuete
Southern California
Can't hurt. What I would do personally before spending a ton of money is just get a pair of old beat up 550s on eBay or such and do some testing. Sometimes you can find a pair for under $100. Your mileage will definitely vary with these things, but I have had extremely good luck.
W5JG
Just tried a pair on a container ship. Amazing coverage, from the bridge, all the way down into the engine room.
kd4e
Nevils, GA
We're testing a DTR650 to multiple DLR1020's (connected to rechargeable amplified speakers) as a wireless PA system.
The DLR1020's never transmit (other than an acknowledgement back to the DTR650).
With a full charge they're supposed to be good for 14 hours - 10% transmit, 90% receive. (They're not getting a fraction of that transmit activity.)
The batteries (new) are failing in less than 17 hours.
Has anyone observed this? I bought all the batteries from the same source.
They're labeled "KOVHIHAV HKNN4013A Li-ion 1800mAh/6.66Wh 3.7V"
Thanks.
K2NEC
5F6
So....they're doing exactly what they're supposed to be?
Wicho
Never never land
Could be the cells aren't the stated capacity. I'm not familiar with the Kovhihav brand, but see them on Amazon.
Also, the instruction book I've seen for the DLR1020 states UP TO 14 hours based on 5/5/90 with battery save turned on. 10-12 hours with it off.
Do you have battery save turned on? Should be on by default but you never know. Regardless, 17 hours is pretty good IMO.
*edit* - could also be some other type of drain going on. I have two 1020's that will drain a battery in 24 hours while turned off.
kd4e
Nevils, GA
Did you fully charge the battery at least for 24 hours before you used it?
Yes. They've all been through multiple charge cycles - using a Motorola PMLN7135A 12 Pocket Multi-Unit Charger.
kd4e
Nevils, GA
Only 17 hours in 99% listening-only mode? I'll check the battery save setting - thanks. (I looked for individual chargers but the best price I could find is about $40. each - which is more than I paid for a used DLR1020 radio plus a new battery. Specs say that the DLR1020 can be used while charging.)
kd4e
Nevils, GA
Perhaps the batteries are defective? We're checking on the battery save mode. Draining a battery while "off" is really weird - I'll have to Search for info about that anomaly. Thanks.
