zumachris
I am having difficulty in programming talk groups into my BC-296-D with a group that contains a Motorola EDACS networked analog system. The frequencies, talk group tag and other data program fine, but the actual talk group codes don't take when I read the radio back. I have also tried it manually without Uniden and ScanCat softwares.
Of course it would help if I knew what format the group codes are supposed to be entered. For an example, Do I use the DEC code or the AFS code numbers. I have tried both. In this sites Florida section for Collier County it says that group 15-157 (AFS) is busy, but is that what I use? In the instruction manual for the Uniden 296-D, it states use the agency code 15- seperated by a dash, says to use a period instead of a dash, then the specific group number 157. I tried it with a dash and period and it won't take. The Uniden software instruction sheet for the 296-D seem to contradict the owners manual. There it says to use a dash, not a period for imputing talk group data. Hummm, which is right?
Any help would be greatly appreciated!
