Motorola HAB1004A Broadband Antenna Matcher - SYNTOR X9000
RFI-EMI-GUY
Ok I have a couple of these Motorola antenna matchers. Specifically the HAB1004A for 33-43 MHz using a 78.25 inch whip. The manual below is similar.
Questions:
1) By what principal do these antenna matchers work?
2) Will they work with a base loaded (NMO xx) antenna?
3) If used with an NMO mount, can I install the matcher remotely from the NMO base by using 1/2 wave of cable in between?
prcguy
In most cases the recommended whip length is about mid range for the useable frequency range of the matcher. The matcher also needs a specific length of coax so its just providing a little better match over about twice or three times the normal range of a stock 1/4 wave whip. I think there are too many variables to say if it would be useable with a base load or any other kind of antenna.
RFI-EMI-GUY
I am thinking the theory is somewhat like the matcher below. I have no desire to use a 1/4 wave whip, but would like to increase bandwidth of an NMO base loaded.
  • ARC44 AT454 antenna.pdf
RFI-EMI-GUY
Have you considered a laird wide band NMO? They make them in several VHF lo ranges that cover about 7MHz of band width and they have similar band width to the Motorola matcher.
I found these the CW27 may be useful at 2.9 MHz BW. I need something to cover 43 MHz and above as well. Are these the antennas? I wonder if these are the ones shipping with Loctite?
RFI-EMI-GUY
Or there are several broad band military whips that cover about 30 to 90MHz with no tuning and they could probably be slightly modified to cover 10m through at least 6m.
I am mounting on an SUV, Ford Expedition that offers little in the way of mounting a military type whip mount.
prcguy
Those are them. I have an ex CHP CW37 (in black) that covers 37-46MHz with a great match. Those show up on eBay occasionally for good prices. I also have two CWB27s for CB/10m use and they are excellent antennas.
